Gas Heater, Extended Recovery Time, Perceived Low Volume of Hot Water
Discussion in 'Water Heater Forum, Tanks' started by budrn, Sep 2, 2013.
  1. budrn
    budrn New Member
    Sep 2, 2013
    Amarilllo, TX
    I have a gas fired heater, approximately 8 years old. I am the only one in my household. Recently, the heater takes hours to replace the hot water I use. If I shower there is little really hot water to use in the kitchen and it may be 4-6 hours before I have any available again. It may be my imagination, but it seems a couple of times during extended showers, I ran out of hot water towards the end of the shower and had to keep adjusting the mix valve to less cold. I can't figure this out since it seems to be a volume related problem and not the ability to heat to acceptable temperature. Any ideas are appreciated.
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    There are a few things you can try to improve the situation, but...
    IMHO, your water heater is shot. Replace it.
    Next time, flush the heater annually.
  4. budrn
    budrn New Member
    Sep 2, 2013
    Amarilllo, TX
    Could you explain this more fully? Have I damaged it somehow by not flushing it? What happens? Most neighbors have gas heaters as well, and never in 50 years have I heard of one being flushed. I am ignorant in this department. Thanks.
Similar Threads: Heater Extended
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Today at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks HW Heater to tankless coil Feb 13, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
