Gas connections for stacked dryer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mad Plumber, Oct 23, 2008.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    The installer needs at least six feet for the flex connector on the stacking gas dryer.
    Can I use two 48" flexes and connect them together?
    I find anything longer than 48"
    B Lewis
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    No, but you can get a 6' piece of csst and the fittings thouth without a license no one will sell it to you.
  4. hj
    Csst
    Please read your CSST manufacturer's manual. It states that CSST CANNOT be used as an appliance connector.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    No, but it can be used to extend the existing pipe and then a short appliance connector can be attached to it. sorry for not being specific enough.
  6. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I've seen six foot flex lines. Under IRC and UPC they are allowed for ranges and dryers.
  7. jimbo
    jimbo Plumber
    I have seen 6 footers in the 5/8 size for ranges. I have not seen a 6 footer in the 1//4 " for dryers. You definitely cannot put two together. It would be a fairly simple matter to put an elbow ahead of the gas valve and run a pipe vertically say 4', then put the valve up there.
    Naturally, that pipe would be secured to the wall in some way, and as with ALL gas work, you have to pull a permit on this.
  8. kingsotall
    Aug 17, 2008
Similar Threads: connections stacked
Plumbing Forum, Professional & DIY Advice NPS (Straight Thread) Fitting OK for Hidden Connections? Apr 5, 2016
Plumbing Forum, Professional & DIY Advice Best Pex Manufacture for Cinch Connections? Feb 7, 2016
Plumbing Forum, Professional & DIY Advice Pool filter connections May 29, 2015
Plumbing Forum, Professional & DIY Advice how to buy/make new connections to water meter Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Push-Fit Connections and Deburring - a minor but important question Jul 2, 2014
