Gas black pipe run?
Discussion in 'UPC Plumbing Code Questions' started by phinkel, Jan 1, 2011.
  1. phinkel
    phinkel New Member
    Mar 28, 2010
    Cincinnati
    I need to move my gas water heater(WH) over about 6 feet to make run for a new location for a gas dryer hook-up. Currently a single 3/4" line is feeding two tees of 3/4" lines which feed the dryer and WH. Each, dryer and WH have 1/2" reducers at the end of the lines.
    Can I run both the dryer and WH off of a single 12' x 3/4" line reducing the line to a 1/2" at the end of each feed? I don't want to starve either of two units which could run at the same time. The WH is a 50 gallon 40,000btu unit.
    thanks,
  2. hj
    As a practical matter, probably yes, but the theoretical answer would require more information than you have given us.
  4. phinkel
    phinkel New Member
    Mar 28, 2010
    Cincinnati
    information such as?
  5. hj
    distance from the meter to the LAST connection in the system, and sizes of ALL the pipes to the point where the dryer connection is made to the main line, being two of the major ones.
  6. plummen
    plummen New Member
    At what point does your gas line get reduced to 3/4"
Similar Threads: black pipe
UPC Plumbing Code Questions Standpipe/p trap in crawlspace Feb 9, 2017
UPC Plumbing Code Questions Waste Pipe Above Ground Feb 12, 2016
UPC Plumbing Code Questions Standpipe Maximum Height May 16, 2015
UPC Plumbing Code Questions double soil pipe system to keep "grandfather clause"? Nov 15, 2011
