Gas appliance pipe run and shutoff
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jwray, Dec 30, 2005.
  1. jwray
    jwray New Member
    Oct 25, 2004
    I am remodeling (reconstructing would be a better word) my kitchen and will be adding a gas range.
    When I had my furnace and hot water heater (both gas) replaced a few years ago I had the contractor leave me a tee and capped nipple which I could extend to the future gas range (total pipe length from the tee will be just a few feet).
    BTW I am in VA and under the IRC code.
    I have 3 questions re: the pipe extension to the gas range:
    1. Can I use a coupling to replace the cap and extend from the nipple or would it be a better idea to remove the nipple from the tee and install the correct length pipe in the tee.
    2. The water heater is a direct vent type (through the outside wall). The most convenient way to run the gas line to the range would route it over the water heater exhaust pipe. Are there any restrictions on this or requirements for space between the exhaust and gas runs?
    3. The code requires a shutoff close to the appliance, in the same room, accessible, etc. If I run the gas line up through the floor per the range mfg instructions and install the shutoff there it will only be accessible if you move out the range to get to it. If I need to shutoff the gas here in an emergency I shure don't want to have to wrestle with a 300 lb range to get to it. Even if this does meet code (the shutoff under the range) is it OK to put 2 shutoffs on the same line, 1 under the range in the kitchen and 1 in the basement close to the point where it goes through the floor. This second shutoff would be in a different room, but accessible with a quick run to the basement if there was a problem.
    Thanks for the help.
  2. kipph
    kipph New Member
    Dec 28, 2005
    I had the same problem when remodeling my kitchen just a year ago. Well not the direct vent WH problem. But my plumber had a shut off @ the Tee & also at the appliance, even thou I had a gas cooktop & wall oven config. He also stated the same code "excessive shut off", but we installed it behind the appliance that would never be accessed. The shut off at the tee should be fine (i'm assuming that the distance between the 2 is not that great).
    As for piping what are you using: Flex or Cast Iron. Cast Iron would be better.
    I looked really quick in the International Fuel & Gas Code 2003 & could not find any min. separations but I would play cautious when running any Fuel piping near a heat source (cast Iron & max distance from vent).
  4. jadnashua
    Sometimes, people run the gas line through a cabinet and put the shutoff there. I had the plumber put a shutoff behind the stove, and one below it in the basement ceiling. Don't think it is a problem. I think my stove is closer to 500 pounds AND it is on a 3" raised platform along with the cabinets (I'm tall, and wanted it at a more comfortable height), so to get behind the stove, you need to move it out on blocks...
  5. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Shut-offs are required immediately upstream of (before) flexable appliance connectors. If the final hookup to the appliance will be with such a connector, remember that the connector cannot pass through any partition, be it a cabinet, wall or floor.
    An auxilliary shut-off in a more accessible loacation is always welcomed.
Similar Threads: appliance pipe
Plumbing Forum, Professional & DIY Advice All appliances are working properly but my outside pipe is overflowing!!!! Sep 23, 2010
Plumbing Forum, Professional & DIY Advice Appliance company thinks my dishwasher install is complicated... Apr 18, 2016
Plumbing Forum, Professional & DIY Advice Natural gas and multiple appliances Nov 4, 2014
Plumbing Forum, Professional & DIY Advice bad drop in water pressure when more than one spigot/appliance is turned on. Oct 11, 2013
Plumbing Forum, Professional & DIY Advice Appliances - Dry Rot? Apr 6, 2013
