Model Badger 1-79A
My wife put potato peelings down the garburator and when she went to use it it wouldn't drain, here's what I did.
First made sure the garburator was rotating ok and it was,next disconnected the ABS drain pipe which discharged a load of water (checked trap, it is ok)
If I leave the drain pipe disconnected and run the garburator, contentsr shoots out no problem, if I connect it up, it won't drain.
Motor appears to be running normally, eats ice cubes, (pipe disconnected) but doesn't if pipe reconnected.
Any suggestions?
Any suggestions?
