garbage disposal overflow to other sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by boDoanh, Jun 9, 2009.
  1. boDoanh
    boDoanh New Member
    Jun 9, 2009
    I replaced a garbage disposal 1/2 hp, Insinkerator Badger 5) under a double-sink. I would like some help determining how to prevent water backed up over other sink when in use.
    With the stronger disposal (1/2hp vs. old 1/3hp), the water could not drain to the main pipe (through P-trap) and some popped up other sink. When I removed the Air Admittance Valve, problem went away.
    How can I fix this problem? Your assistance is greatly appreciated.
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    The problem is the lack of a proper vent. The unit is causing a positive pressure in the drainage line which is the issue.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    You didn't happen to put the tailpiece in upside down....don't know if it's possible but if it worked before and doesn't work now.
  5. hj
    drain
    There are many possible causes an obstructed drain being the first option, especially since removing the AAV eliminates the problem. Or there might be a missing baffle tee, or.................
  6. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I skimmed over and missed the AAV part. OP - your AAV may be bad, try to replace it.
  7. boDoanh
    boDoanh New Member
    Jun 9, 2009
    Yes, I think lack of proper vent is the problem. When I remove the AAV, problem goes away.
    The pipe goes from the disposal into side of a T (other sink goes straight down into top of the T), other end of the T goes to a P-trap and out to the main pipe which an AAV is installed.
    I didn't have this problem with a weaker 1/3hp waste disposal.
  8. Terry
    Aug 17, 2004
    [​IMG]
    Most plumbers would have used a disposer kit, straight from the disposer into a baffle tee.
  9. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Is the drain partially plugged? A Badger V isn't a particularly powerful disposer - it should handle a 3/4 horse disposer just as easily. And I have no idea why removing the AAV would make any difference. If the drain can handle the discharge, even a complete absence of a vent shouldn't make a difference.
    Does the kitchen drain connect to a larger pipe under the floor, or does it go out to a drywell? If there is pressure resistance in the pipe there is bound to be a problem somewhere in the line. For example, it might have a swale in the pipe that is full of water. Or it may be that it's mostly plugged and the water goes through very slowly.
    I'd fill both sinks to the top without running the disposer and see if they drain quickly.
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Not only that but all that tubular 1 1/4" pipe will be holding water to the level of the dirty arm.
Similar Threads: garbage disposal
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Garbage disposal / P-Trap Mismatch Nov 1, 2016
