Garbage disposal drain????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Slfrat, Sep 30, 2013.
  1. Slfrat
    Slfrat New Member
    Sep 30, 2013
    Calgary
    I realized after the fact that this isn't the correct way to install a drain on a garbage disposal. Question is, is there anything about the way it was done that could cause problems?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It's hard to tell what you have because your picture shows black on black, but I think if those 2 P traps are connected, you have an illegal S trap. ABS pipe and fitting are cheap, so I would just remove the whole mess and start over and do it right.
  4. hj
    It is NOT an "S" trap, nor is it a "double trap", but the trap at the disposer is useless and not necessary. The tee that the disposer is connected to is upside down. So other than these two "defects" and it not being how I would have done it, it is a good DIY kludge. You could also reposition the weight on the sink hose so you could pull the spout out further.
    [​IMG]
  5. Terry
    Aug 17, 2004
    [​IMG]
    This would be cleaner. Remove the 90 bend that came with the disposer and pick up a disposer kit with baffle tee.
    [​IMG]
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    The new picture helped me see what you have. It still is a mess and I'd redo it.
Similar Threads: Garbage disposal
Plumbing Forum, Professional & DIY Advice Garbage Disposal Backs up 2nd sink help? Mar 1, 2017
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
