Garbage Disposal ---Arg!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sinkerator, Jan 1, 2008.
  1. sinkerator
    sinkerator New Member
    Jan 1, 2008
    Teacher
    Evansville, Indiana
    I peeled potatoes and put the peelings down the garbage disposal. It seems I put too many and now I have water/ peelings standing in the disposal side of the drain only. Water flows fine down the standard side. I tried tapping on the pipe connecting to the standard drain put dont know where the clog is directly. What would be the safest, cheapest, and easiest way to fix my potato peeling problem? Thanks!
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    use the plunger....LUKE....
    The potatoes are stuck in the baffle
    Tee under your sink... they cant make the bend..
    try useing a plunger on the garbade disposal side
    of the drain with water in it and you might be able
    to dislodje the potaote peels
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Can you pull apart the pipes between the disposer and the tee?
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I would do that.
    If you plunge the drain you may end up sending the clog down.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    That should do a good job of pushing water into the dishwasher or, making an air gap geyser!
  7. sinkerator
    Jan 1, 2008
    Teacher
    Evansville, Indiana
    Yay! New Year's dinner is now saved!
    The kraut and sausage is ready.. come and get it! Now I can wash my dishes! I tried the plunger first and low and behold it worked. Thanks for the suggestions. I would love to help anyone who needed it, if only I wasnt a new home owner and dont really know many fix it problems yet. The next task is to fix a hole in the wall, scrape the acoustical popcorn from the celing and put new shingles on the roof.
    Thanks again!
  8. Cookie
    Cookie .
    Oct 7, 2005
  9. Master Plumber Mark
    Feb 6, 2005
    do it all the time
    its worth a shot.....
    you dont know if they even have a dishwasher....
    it works about 75% of the time
    or you can take everything apart under the sink
    whatever they feel is the easiest way
    to make it go down..
  10. sinkerator
    Jan 1, 2008
    Teacher
    Evansville, Indiana
    celing
    Thanks for the advice on the popcorn. The previous owners installed the popcorn, he did a lot of remodeling to the house. Sad to say some of it was done poorly, but done none the less.
  11. hj
    stop
    Now you have to find out why the disposer pulverized the peels instead of grinding them. It could have just been too much too soon, but it could also be because the grinding ring and plate are worn out.
  12. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    Potato peels are not a good thing to go down a disposal...I've lived in several places, and am yet to see a GD that handles them well.
Similar Threads: Garbage Disposal
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Garbage disposal / P-Trap Mismatch Nov 1, 2016
