Garbage Disposal and Dishwasher problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cbalding, May 25, 2006.
  1. cbalding
    cbalding New Member
    May 25, 2006
    Small problem and I can't quite figure out what the problem is. I had to replace my garbage disposal. Got a new one, replaced it. Hooked up all the old lines into their proper places and away we go.
    The only problem is now when I run by dishwasher, instead of draining completely through the drain line, a fair amount of water comes out of the over flow line next to the faucet.
    The garbage disposal works fine. I have stuck a snake down the pipe with no apparent problem. I have reconnected everything and checked all the connections. There are no leaks from the garbage disposal itself. All the pipes are tight.
    I can't figure out where the problem is. It is only when I run the dishwasher that water comes out of the overflow next to the faucet. Any help would be appreciated.
  2. Jeff1
    Jeff1 New Member
    May 24, 2006
    So Cal
    Did you remove the plug from the disposal where the dishwasher connects to it?
  4. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    you need to bang out the plug inside the drain port of the garburator, which is what Jeff said. Imagine if you wanted a garburator, but not a dishwasher - this is how you could accomodate everyone! I would remove the garburator, lay it on its back with the drain port facing up, take my big utility flathead and give it two good whacks with a hammer... keeping in mind that this is an appliance, don't be too rough with it.
    ~k~
  5. cbalding
    cbalding New Member
    May 25, 2006
    Thanks
    Thanks. That was the trick. Didn't even know that was a problem.
    Christopher
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Too bad every problem isn't this easy to diagnose!
Similar Threads: Garbage Disposal
Plumbing Forum, Professional & DIY Advice Garbage Disposal Backs up 2nd sink help? Mar 1, 2017
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
