Garage floor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Cookie, Jul 12, 2006.
  1. Cookie
    Cookie .
    Oct 7, 2005
    What causes dark stains on the garage floor? Thanks.
  2. hj
    stains
    Ground water could only come up through the concrete if it was under pressure and that is very, very unlikely. Put newspapers on the floor under the car. It is probably fluid leaks of some kind. Wherever the stains mark the paper, the leak is somewhere above it.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I had a similar stain in part of my garage which is now a formal laundry room. I just covered it up yesterday with ceramic tile. There's a similar stain in the master bath, which will be tiled next week, Imshallah :) .
  5. prashster
    prashster New Member
    Dec 7, 2005
    It doesn't sound like water seepage. Water doesn't behave like that - in isolated spots.
    You need to take a picture of this and post it.
    Could the stains be mold? Dampness and darkness would make it appear on the surface. Light and drying out would make it recede below surface. I doubt, though, that you'd mistake mold for a liquid stain...
    Another way to refute the theory that it's water seepage is to lay some clear polyethylene down in a large square. Tape the edges sealed. If you get no condensation after a few days, then you don't have moisture seeping through the slab.
Similar Threads: Garage floor
Plumbing Forum, Professional & DIY Advice installing a bathroom in second floor garage Jun 16, 2016
Plumbing Forum, Professional & DIY Advice Sewer gas from garage floor drain Nov 24, 2014
Plumbing Forum, Professional & DIY Advice Adding garage utility sink - use existing 1st floor bathroom drain and vent? Nov 13, 2014
Plumbing Forum, Professional & DIY Advice Garage Floor Drain Jan 27, 2012
Plumbing Forum, Professional & DIY Advice Bathroom drain problem - sharing with garage floor drain Jun 13, 2011
