garage floor drain question
Discussion in 'Drain Cleaning' started by alaskapanic, Jul 17, 2011.
  1. alaskapanic
    alaskapanic New Member
    Jul 17, 2011
    Alaska
    1st post on the forum
    garage floor drain backing up when wife washes clothes. we have a private well and septic. after the wash is done it does go back down, but if i shine a flash light i can see water standing(down in the pipe a ways). in alaska some people recommend pumping their septic every year. don't know if that's overkill, but that's what i hear. anyway, skipped pumping last year and don't know if that's coincidence or related? question is what to do? try buying a snake? not sure if you snake in the floor drain itself or down in the crawlspace where all the plumbing is? any other suggestions appreciated
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    A floor drain should have a trap, so you should see water in the pipe.
    You can snake it, but you would be wasting your time if the holding tank needs to be pumped.
    If I were on a septic system, I would know how to check the tank level.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Septic systems aren't meant to be pumped annually, if you need to pump them that often there is something else wrong.
    Do you dump bleach and all kinds of other chemicals into your drains or what?
  5. hj
    If your garage drain is connected to the septic tank, you probably do have to pump it every year, if for no other reason than to rejuvenate it. All the road "scum", salt, and oil that accumulates on the car and then melts into the drain is NOT good for a septic tank. It is also not good for a municipal system either, which is why most municipalities do NOT allow garage drains connected to the sewer system.
  6. schustermarie54
    schustermarie54 New Member
    Jan 7, 2012
    Denmark
    I've seen commercial floor drains built to code. What they look like is a large square hole in the garage floor with a grate over the top of it. A stand pipe comes up in the middle of the hole, flips around forming a trap and then comes straight up to within a few inches of the grate. This forms a large indoor pool to try to trap any fluid contamination before it can get into the sewer system or groundwater.
    It also doesn't work worth a damn, as they fill up with stagnet water and stink to high-heaven.
    Obviously the most important thing is to keep polutants, solvents, contaminants, etc. away from your floor drain. It's not like a dry well is a water treatment facility. If you put anything other than water down that drain, you'll be polluting your own property and likely the water table for the surrounding area.
    Now that you've decided to be careful and only allow water (and maybe a little soap) down the drain, you need to ask yourself why you need a 55 gallon drysump. What I did was run 4" DVW out to a 9" grated box in my yard (about a 9" cube), drilled holes in the box. Ran 10' feet of perferated 4" tile out of the box into a trench, and backfilled the whole set up in a bunch of 11B's. People around here would call that a "French Drain". People in France likely call it something else.
    The way it works, the grate serves as an overflow to let any excess flow into the yard, rather than back up into the garage. I hooked one of my downspouts into the same line.
Similar Threads: garage floor
Drain Cleaning Garage floor drain cover Apr 28, 2010
Drain Cleaning Garage floor drain Jun 18, 2009
Drain Cleaning Garage drain clogged ( with cement ?) Dec 30, 2011
Drain Cleaning Floor Drain Sabotaged With Sacrete Apr 26, 2016
Drain Cleaning Basement floor drain--is it right? Sep 27, 2013
