Gap filing tile floor
Discussion in 'Remodel Forum & Blog' started by gerardw, Dec 29, 2009.
  1. gerardw
    gerardw New Member
    Dec 26, 2009
    CT
    A friend has a tile entryway. The tiles are well fastened to the floor and evenly spaced. The mortar or grout used to file the gaps between the tiles is not flush with the floor which makes cleaning difficult. The gaps are about 1/4 inch wide and 1/8 inch deep.
    Is there something that can be used to fill the gaps flush with the tops of the tile? I understand that removing existing filler and redoing is probably the ideal solution but that's not in the budget for this job.
  2. jimbo
    jimbo Plumber
    Someone was too aggressive rubbing out the grout, or rubbed it out before it was set enough. You could use a carbide hand grout scraper to rough it up and take some out, then regrout over it.
  4. jadnashua
    If you're up for the manual labor, it's not all that hard to regrout. The tools and materials are pretty cheap. Check out www.johnbridge.com for help on tiling issues.
Similar Threads: filing tile
Remodel Forum & Blog Cantilevered bumpout Jan 5, 2016
Remodel Forum & Blog Tiled Doorway In Adjoining Areas Feb 24, 2015
Remodel Forum & Blog Insulating cantilever and rim joists Dec 29, 2014
Remodel Forum & Blog Cantilever insulation/sealing? Sep 23, 2014
Remodel Forum & Blog Going to tile but first need floor insulated - best product Sep 15, 2014
