Gap between shower pan and studs
Discussion in 'Shower & Bathtub Forum & Blog' started by Bratan, Mar 27, 2013.
  1. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    Looking for an advise :)
    I'm installing 4 piece pre-made shower (pan, back wall, side walls) and there's a big gap of 1-1/2" between back wall studs and shower pan :(
    What would be the best way to breach the gap, extend studs? 2-3 layer of 1/2" backerboard or some kind of long wood planks (parallel to the floor)? Some other option?
    Single wood plank will take care of pan problem, but then there's back wall that needs to be installed and then on top of it there will be drywall (going to the ceiling)....
  2. Terry
    Aug 17, 2004
    I would fir out the walls to make them plumb and straight.
  4. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    Thanks Terry! I never heard about firring out, is it something like in this video? http://youtu.be/MLPEUZ7MAUE
    [video=youtube;MLPEUZ7MAUE]http://www.youtube.com/watch?v=MLPEUZ7MAUE&feature=youtu.be[/video]
  5. Terry
    Aug 17, 2004
  6. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    That sounds like a plan, will make 1-1/2 shims out of new stud planks (probably just cut them in half). Thank you Terry! :)
    BTW it's funny, but that's the exact table saw i have :D
  7. jadnashua
    If the walls are not perfectly flat and plumb and in plane with each other, just take a new, full-sized stud and screw/glue it to the side of the existing ones and make it nice and plumb and square. Quicker and easier than ripping a bunch of studs that won't take into consideration any bowing or other issues unless you want to try to make some really long tapered shims, or if bowed, curved, which would be really difficult.
  8. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    Good point! Actually I just got another suggestion from someone. I don't have to rip/cut anything, just buy 2x4 and screw them to the existing stud but at 90 degree angle, so it will be like "T" shape if looking from top/ceiling. Since 2x4 is actually 1.5 inch it would make the gap. But yeah if wall is uneven or new studs wrapped I'll have a problem...
Similar Threads: between shower
Shower & Bathtub Forum & Blog Gap Between Diverter and Shower Wall Oct 23, 2015
Shower & Bathtub Forum & Blog Shower glass installation - less than 1/8" gap between U-Channel frame and glass acceptable? Jul 31, 2015
Shower & Bathtub Forum & Blog Should I seal shower faucet between the escutcheon and the sleeve? Jun 29, 2013
Shower & Bathtub Forum & Blog Quick question on leveling sub floor for Schluter Shower. Between plys or on top? Feb 9, 2013
Shower & Bathtub Forum & Blog Zipponi Thermostatic shower valve leaks between hot and cold Aug 22, 2012
