Gap between ceiling fan housing and ceiling
Discussion in 'Electrical Forum discussion & Blog' started by hfx, Aug 22, 2012.
  1. hfx
    hfx New Member
    Aug 22, 2012
    Johnson City, TN
    Hunter ceiling fan:
    Hi I was wondering if anyone had experience with ceiling fans and could tell me what the deal is with the gap I ended up with between the housing and the ceiling. It almost looks like the bracket was made to hang down some, the instructions didn't say anything about bending it to fit flush with the ceiling, just curious if anyone had the same issues.
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Is the ceiling box (hopefully fan mounting designed and rated) flush or slightly receeded with the sheet rock? Are you able to spread those wires apart somewhat as a seperate issue?
  4. hfx
    hfx New Member
    Aug 22, 2012
    Johnson City, TN
    Thanks. Yea the box is recessed 3/16" or so (yep its made for and mounted for ceiling fan, thanks). You saying I need to give the wires some breathing room from each other? I could probly do that, can I ask why, just so I know.
  5. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    it looks like you're missing a trim ring that covers the screws. Mine has a cover that slides over those and covers that same gap.
      File size:
      23.8 KB
      1,631
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Yours hangs on a stem and his fits flush to the ceiling but I don’t see anything wrong.
    I would much rather have the small gap as to have it damage the texture of the ceiling trying to install it.
  7. BobL43
    Mar 25, 2011
    Long Island, NY
    If the gap bothers you, a medallion may work for you to hide it. HD and Lowes sell a variety of them. You could also call the manufacturer's customer service to see if they can suggest any possible adjustment. I agree with JW, though. More often than not, it is difficlult to force the canopy up against the ceiling while trying to get those screws threaded into the holes.
    I mentioned the wiring because it does not look so neat. I have installed enough ceiling fans to know that it is not always so easy to make it neat:p, but I always try.
  8. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Looks like good ventilation design to me.
  9. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I agree! I'd leave it alone. No one, but you, will ever look at this and think, "What a horribly wide gap!" And you will soon think of other things and will stop noticing it.
  10. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is what I was thinking, It will sure run cooler.
    Plus the spiders have a escape route.
  11. hfx
    hfx New Member
    Aug 22, 2012
    Johnson City, TN
    Hey I appreciate it guys. Yea I know I'll def get used to it being like that. I'm glad you all feel this way, now I won't feel compelled to take it back apart and fix anything. And if I do I can find an alt to the actual housing sitting flush. Thanks
  12. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Every once and a while we have someone ask a question and get an answer that they are satisfied with but more times than not we have someone who thinks we are picking on them.
    It pleases my heart when we do give someone an answer that makes them happy so I thank you for posting this.
    Mike
  13. oldanbo
    oldanbo New Member
    May 30, 2006
    Sequim,WA
    HEY, that's my fan! ;) HD or Lowes, I forget.
Similar Threads: between ceiling
Electrical Forum discussion & Blog Switching between AC and MC cable? Oct 13, 2016
Electrical Forum discussion & Blog 200 amp service split between two panels Mar 14, 2016
Electrical Forum discussion & Blog What might I have hit between brick & bearer? Sep 8, 2014
Electrical Forum discussion & Blog Mounting outdoor outlet help needed - preference between two examples shown Aug 31, 2014
Electrical Forum discussion & Blog No ground wire between meter entrance and house panel Aug 18, 2012
