galvanized to abs dwv?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fetchmore, Mar 7, 2007.
  1. fetchmore
    fetchmore New Member
    Mar 7, 2007
    I need to remove the old 2" galvanized drain, trap and branch from my main stack. That will leave me with a cast iron 2" female npt. I would like to know what the best method would be for screwing in the new abs 2" male npt.
    thank you
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    [​IMG]
    Go with PVC... (oersonal bias)
    Buy a 6" Schedule 80 nipple and cut one ond off ,,,
    Screw this nipple into the female cast iron and continue your waste using a coupling at the other end...
    The SCH80 nipple is vastly stronger than any DWV male adapter...
  4. fetchmore
    Mar 7, 2007
    thank you........use dope, tape, or both?
  5. jadnashua
    I think I'd use a good dose of dope.
Similar Threads: galvanized
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Galvanized compression coupling Aug 1, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
