Galvanized springing leaks.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hornnumb2, May 31, 2011.
  1. Hornnumb2
    Hornnumb2 New Member
    Mar 15, 2011
    TX
    In the past month I have had 2 pin holes in my galvanized water line in the attic. I live in Texas and I am trying to figure out how to make it last till its cooler in the attic. Does it get holes in horizontal runs more the vertical? Could I just redo the horizontal lines first and it last through till fall? Thanks for any suggestions....Michael
  2. Terry
    Aug 17, 2004
    It's quicker to just replace everything. I can't imagine being in the attic and trying to reconnect new pipe to old rusting galvanized.
    That would be a bear.
    If you need to get by, just throw on some repair clamps.
  4. hj
    IN most cases horizontal pipes DO have more problems than vertical ones, but you also have horizontal lines inside your walls at the bottom of the vertical pipes.
Similar Threads: Galvanized springing
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Galvanized compression coupling Aug 1, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
