Galvanized pipe in newer home?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 68malibu383, Jul 25, 2013.
  1. 68malibu383
    68malibu383 New Member
    Dec 15, 2009
    Colorado
    Found a few short pieces of pipe on a water heater that the homeowner added on a six year old house. I know galvanized can't be used for drinking water anymore and I'm thinking it should not be not be on the hot side either. Someone could use hot water for coffee or cooking. This should be removed, right?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    One can still buy all the galvanized pipe and fittings they want a plumb houses with it. No one does it anymore as we have materials that are easier to install and will never rust like galvanized pipe eventually does.
    Most people are replacing galvanized pipe because of the rust issue. If you are worried about it, replace it.
  4. hj
    The only problem with galvanized water piping, hot or cold, is that is expensive to buy, REALLY expensive to instal, and eventually gets rust holes in itl. Connecting galvanized and copper directly together, however, is not a good idea.
Similar Threads: Galvanized pipe
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
Plumbing Forum, Professional & DIY Advice PEX pipe to replace galvanized Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Galvanized Pipes rusting Jan 20, 2016
Plumbing Forum, Professional & DIY Advice Rusted galvanized steel threads on hot/cold water pipes... Feb 20, 2015
