Galvanized Pipe Elbow Alignment
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Duke76, Aug 28, 2007.
  1. Duke76
    Duke76 New Member
    Jul 10, 2007
    I have a very basic question.
    I'm connecting a length of galvanized pipe with a 90 degree elbow that connects to another length of galvanized pipe. I need to ensure the elbow points in the proper direction to match up with another elbow 10 feet away. If I tighten the elbow as much as I can it points the wrong way.
    Is the proper procedure to tighten as much as possible and then to back it off a bit to achieve the proper angle? And rely upon pipe compound for a water tight fit ?
    Thank you.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    There is a bit of a "touch" involved. You do not want to back it off. The idea is to tighten and know when you are on the last turn, and stop at the right point, or go around again!
  4. JasonG
    JasonG New Member
    Aug 28, 2007
    I read somewhere that after hand tightening, tighten one complete turn with a wrench and then continue to tighten to alignment. Is this good advice?
  5. hj
    pipe
    Very bad advice.
  6. Duke76
    Duke76 New Member
    Jul 10, 2007
    Thanks guys. HJ, are you commenting on JasonG's advice ? Do you agree with Jimbo's answer.
    Thanks in advance.
  7. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    That is the bottom line -- fully sealed and not broken -- and there is no turn-counting formula.
  8. jimbo
    jimbo Plumber
    San Diego, CA
    There are ANSI specs for thread engagement turns, but the spec itself acknowledges that there is so much variance from ideal in the cutting machines out there in the "real world" that the spec is just a guide. Back to the "touch"!
Similar Threads: Galvanized Pipe
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
Plumbing Forum, Professional & DIY Advice PEX pipe to replace galvanized Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Galvanized Pipes rusting Jan 20, 2016
