Galvanized Main to CPVC
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by trinculo54, Oct 10, 2005.
  1. trinculo54
    trinculo54 New Member
    Jun 24, 2005
    Well I am starting my next major project of replacing all of the old galvanized water lines in the house. I have started to run CPVC from the main to the water heater and have temporarily tied into the rest of the cold water. Before I get too far I have a few questions.
    1. The main itself is galvanized, while I would like to replace it now; that will have to wait for another time. Right now the main is ½†galvanized and I have placed a ½†metal threaded CPVC connection with about 3†of ½ and then transitioned to ¾â€. I have read on these boards that CPVC is not comparable to copper…meaning that ¾†CPVC is more like ½†copper and 1†CPVC is like ¾†copper and that ½†CPVC is not recommended.
    My thought was to use a ½†copper transaction at the Main then size up to ¾†using copper and then switch over to ¾†CPVC and run that throughout the house.
    2. Should I look at running a dual line system? I have the room and CPVC is fairly inexpensive. Does this really make that much of a difference since my main is so small?
    3. Back to the sizing issues; when I transfer to the fixtures should I size it to ¾†copper and then down to ½†copper to make the connections or am I safe just reducing down to the ½†CPVC for the last foot or so and then making the connection.
    I know a lot of information, but any thoughts or ideas would be great.
    Thanks…you guys have always been helpful!
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Forget the CPVC and stay with copper. I'd look at 3/4" main line and then drop to 1/2".
  4. trinculo54
    Jun 24, 2005
    While I think copper might be the way to go, I like working with the CPVC, with as much work as I am doing on the house I would like to keep things simple. Does anyone else have any thoughts? Thanks
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    Why not just do what you want to do. No one here is likely to support CPVC over copper, and since it's your house and you're paying the bill do it your way.
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    cpvc
    1- All plumbing pipes are measured as inside diameter. 1/2" copper is the same as 1/2" cvpc is the same as 1/2" galv. inside......
    2- Get the 3/4" as close to the main as you can.......
    3- Keep the hot and cold service lines 3/4" right to the last two fixtures then split to 1/2".
    4- Then when you run a new water service you will just have to connect.
    I would do copper..........
  7. trinculo54
    Jun 24, 2005
    hmmm....I was under the impression from Terry/maybe HJ (http://www.terrylove.com/watersize.htm) that Cpvc had a smaller bore. Anyway thanks for the advice...still not hot on the idea of switching my plans to copper :)
  8. hj
    sizes
    Plumber1. you are correct up to a point. Copper and steel pipes, (schedule 40, since sch. 80 has a thicker wall but the same o.d.), are measured by their i.d.'s. But CPVC, PEX, some polyethylene, etc. are CTS, which means their outside diameter is the same as copper tubing, but since the walls are thicker than copper, the inner bore is reduced in size. AND, if you remember your geometry, the greatest reduction in size happens when you reduce the diameter of a circle, which means that "slight reduction" in size can produce a big reduction in capacity.
  9. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    You'll be just fine with CPVC . It's good pipe . Run as much 3/4" as you can then reduce to 1/2" . Remember : When copper came out all the guys who had been running galvinized water lines said ," That stuff is CRAP ". They were wrong . CPVC is good pipe , give it a try.
  10. hj
    cpvc
    CPVC is "good" pipe until it cracks in a hot attic.
Similar Threads: Galvanized Main
Plumbing Forum, Professional & DIY Advice Galvanized pipe to water main? Apr 26, 2008
Plumbing Forum, Professional & DIY Advice 82 year old galvanized main into house Nov 29, 2005
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
