Galv pipe vs balck iron/ teflon tape
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Riosman, Feb 26, 2007.
  1. Riosman
    Riosman New Member
    Sep 24, 2006
    Two questions
    1. The inspector said to never to use teflon tape on gas pipe. Use dope. He stated never to use teflon tape on pipe threads
    True?
    2. Gas pipe under a raised floor: Galvanzed or black iron?
  2. jadnashua
    There is a teflon tape approved for gas (I think it is yellow?), but most people use pipe dope. But, you do what your local inspector wants...
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I have heard gas should never be in galvanized because of the possibility of internal flaking that can cause havok in valves.
  5. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    That was back in the day, now galvanised is o.k. for gas.
  6. hj
    pipe
    galvanized is not only proper for gas, but is required in some situations, such as exposed outdoors. The main reason for using black pipe is that it is cheaper.
  7. leejosepho
    Nov 23, 2006
    Whew, I am sure glad to hear that! In a few minutes, I am headed over to install a new blower motor in a widow's furnace, and I have been afraid to tell anyone that the last time I was there I had noticed the incoming gas line is galvanized!
  8. Rancher
    Rancher Guest
    And if you bury it it has to be wrapped anyway.
    Rancher
  9. Rancher
    Rancher Guest
    I'd always heard it was because a piece of the tape might break off and plug up an oriface.
    Never did make sense to me.
    Rancher
  10. leejosepho
    Nov 23, 2006
    I know of a situation where someone should have never been allowed to use pipe dope. He used so much and gooped it so heavily around the very end of the pipe that the water in the house tasted just like the stuff for several months afterward.
  11. coz
    coz New Member
    Feb 27, 2007
    MA
    I heard what rancher heard...plugs up gas valves
  12. hj
    buried
    You cannot legally install black pipe underground even if it is wrapped, unless it first has a factory coating applied to it.
  13. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    4 TIGHT wraps of teflon tape than pipe dope. with this you will be able to back off a fitting 90 degrees and NEVER have a leak. teflon put on LOOSLEY is what causes problems
  14. Rancher
    Rancher Guest
    Is this a new change to the code?
    Rancher
  15. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    It is in the 1994 UPC - so I don't know if it qualifies as NEW...
    sec 1211.5 and 1211.7
  16. jfkopper
    jfkopper New Member
    Feb 14, 2007
    At least one state's plumbing code forbids the use of galvanized pipe for fuel gas plumbing. (Whether this prohibition is scientifically valid---I don't know.)
    As always, best to do what the AHJ requires.
    Be safe,
    /kop
  17. hj
    rule
    It has been the rule since at least 1970, and probably a long time before that.
  18. FredC
    FredC New Member
    Feb 17, 2007
    Tape Vs Dope + new gas water trap questrion
    I was told 2 wraps of yellow teflon + dope on balck pipe. Never heard of that before & always used Rectorseal alonefor balck pipe. Is this OK or should you stick with one vs the other?
    Do you need to install 3" long drip trap at the end of a vertical line going to a cooktop for propane??????
  19. mrclean
    mrclean New Member
    Feb 7, 2007
    Have always been told that drip leg lengths dont really matter....more a matter of preference with the local inspectors around here. And, the only gas piping we can bury is soft copper.
Similar Threads: Galv pipe
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
Plumbing Forum, Professional & DIY Advice PEX pipe to replace galvanized Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Galvanic Corrosion when pipes aren't in contact Jan 26, 2016
