Gallons per minute
Discussion in 'Irrigation / Sprinkler Forum' started by Siestabob, Dec 20, 2007.
  1. Siestabob
    Siestabob New Member
    Dec 19, 2007
    I have 4 sandpoint well 23'. With a 1 hp pump it can produce 15 gal. per min. for about 7 mins and then it goes down to 5 gpm. How many sprinklers can I put in one zone? What is the average run time for a zone?
    Thanks
    Bob
  2. jimbo
    jimbo Plumber
    San Diego, CA
    A typical pop up sprinkler...full circle, about 3.5 GPM. Half circle = 1.75GPM
    Make a trip to a landscape supply. There are many options for you in terms of lower flows.
    To determine zone run time, you have to consider the head. The figure you need to know is precipitation rate, which is how many inched of water per minute fall PER SQUARE FOOT of area. Fixed sprays have higher precip rates than a lot of the rotors, so can run for shorter time.
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Design with the lower 5 gpm number, which, for a well point, would be something like two standard rotor heads from a big-box store, and a half-horsepower shallow-well jet pump could supply that amount of water.
  5. Siestabob
    Dec 19, 2007
    Thanks for the replys. I will check with a store about possible options. What about getting a storage tank with a pressure tank?
    Thanks
    Bob
