fuse box mystery
Discussion in 'Electrical Forum discussion & Blog' started by dianemahardaiken, Jun 6, 2010.
  1. dianemahardaiken
    dianemahardaiken New Member
    Jun 6, 2010
    As a new home owner I am completely ignorant of all things electrical so any suggestions on wth happened here would be appreciated. Scenario is that my husband was changing a lightbulb in the kitchen the bulb broke while removing and seemed to blow the fuse. So we flipped the switch off on our 100 amp fuse box while he removed the remainder of the blub. All is well, we flip the switch back on and ...nothing. Husband changes the fuses to new ones and still zip, try new ones again and again nada. End of story is that we have no power to half the kitchen and the kids room above. Is it possible the fuse receptacles are shot? they appear to have no damage so ???? We removed the fuses all together because I have a probably irrational fear that this will cause the house to burn to the ground. Any suggestions?:confused:
  2. jadnashua
    Well, you should be able to reinstall the fuses without worry.
    Are you sure the fuse you replaced was any good? Some are fairly easy to tell, some are not. The only real way to tell is with a meter, or to substitute one that you know worked in one circuit into the one that didn't work. Putting a bigger fuse in than the wires are designed for could cause overheating, but not replacing with the proper size.
    While fuses work fine, they are a pain when one gets blown as opposed to a more modern circuit breaker, which will work many times before needing to be replaced...just flip it all the way off, then back on, and you've restored power once the problem has been resolved.
    On an older house, the wiring and insulation can become brittle. So, even some slight movement could cause the insulation to break off. So if that is the case, a new fuse might trip as soon as you install it if there is now a short. You'll need to do a careful visual inspection and you may see the problem...otherwise, it's time for an electrician. the most likely place is the light fixture you were replacing the bulb in. Take the fuse out while poking around!
  4. hj
    In the first place, breaking a bulb would NOT blow a fuse, which means there is something else at work in your problem. The only way to diagnose the problem is with a proper tester using LIVE circuits, which also means it may not be a DIY task for your husband.
  5. bpetey
    bpetey Member
    Jan 12, 2010
    I don't know why a light wold be on a gfci circuit but who knows how your house was wired . I would go around your house to make sure none of the gfci's are tripped. My last house had a gfci outlet in the garage that fed 3 bathrooms and the outside outlet.
  6. worsnup
    worsnup plumbing contractor
    Jun 7, 2010
    plumbing contractor
    phoenix az
    check for gfci outlets
Similar Threads: fuse mystery
Electrical Forum discussion & Blog 1 fuse getting hot, was corroded, fuse out, how do I fix? Dec 29, 2015
Electrical Forum discussion & Blog fuse gets extremely hot and lights flicker Sep 3, 2013
Electrical Forum discussion & Blog Can Screw In Fuses be Safe If Sized Correctly? Aug 25, 2013
Electrical Forum discussion & Blog Fuses getting very hot in Fusebox Jan 23, 2013
Electrical Forum discussion & Blog Old fuse box blowing large fuses but turn on dryer and power is back on? Dec 20, 2012
