Fuse blown after plugging in heater now light dims when another is turned on.
Discussion in 'Electrical Forum discussion & Blog' started by georgiadaisy, Mar 28, 2008.
  1. georgiadaisy
    georgiadaisy New Member
    Mar 28, 2008
    Fuse was blown in box after a heater was plugged in--now lights are not as bright and when another one is turned on they are both dim. Some of the outlets won't work either. We have replaced ALL of the outlets in the immediate area--working and not--but still no help (note--not all of the outlets in the house). Someone that does electrical said it would be the outlet before or after where the heater was plugged in. Lived in the house 12 years and never a problem (or a blown fuse). Please help!!!!:(
  2. hj
    It sounds like you have a defective circuit, and things are operating in series. If so, we cannot help you because it takes someone on site with testing equipment to diagnose,and cure, it.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You can't figure out problems without a meter. You need a multimeter that measures Volts and Ohms, and must learn enough about electrical systems to know how they are connected and what you should be measuring.
    If you aren't prepared to do that you will have to find someone who understands how and why things work, and what could cause the symptoms you are observing.
    You could have a bad neutral connection, or a bad wire connection. There is a circuit called a multi-wire branch circuit that is especially susceptible if there is a bad neutral connection. The problem if you have a multi-wire circuit is that a neutral failure can cause very high voltages across some lights or appliances and damage the appliances or blow the bulbs.
Similar Threads: Fuse blown
Electrical Forum discussion & Blog AC Blown Fuses at outdoor disconnect Jun 26, 2007
Electrical Forum discussion & Blog 1 fuse getting hot, was corroded, fuse out, how do I fix? Dec 29, 2015
Electrical Forum discussion & Blog fuse gets extremely hot and lights flicker Sep 3, 2013
Electrical Forum discussion & Blog Can Screw In Fuses be Safe If Sized Correctly? Aug 25, 2013
Electrical Forum discussion & Blog Fuses getting very hot in Fusebox Jan 23, 2013
