Furnaces in the winter
Discussion in 'HVAC Heating & Cooling' started by gundijones, Nov 28, 2012.
  1. gundijones
    gundijones New Member
    Nov 28, 2012
    Romania
    Before the weather turns cold, make sure you don't need furnace repair and replacement. Nobody wants that on a winter day. To make sure everything works the way it should, replace your filter and check it every month thereafter. Clear away anything blocking your vents or return air vents. Make sure the vent area of your furnace is clear. Vacuuming and cleaning around the furnace area is a good idea. Check furnace belts and motor operation. If they are worn or cracked, then you need furnace repair.
    As a side note, if the dry air is too much for you, consider getting a humidifier installed directly in your furnace. It takes the dryness out of the air so you feel more comfortable, your lips don’t feel quite as chapped and your skin doesn’t feel so dry.
    If you do need furnace replacement then one of the next two things happened to you - first one, obviously, is that the one you have does not function anymore: maybe it has broken down and there’s nothing else you can do or it has been „red-tagged†or condemned by gas inspectors (if you have a gas furnace). The second one is that is getting old, or your fuel bills are becoming too excessive to tolerate. In this case, you have more time to shop around and get the best furnace and fuel that fits your needs. Just call some professionals to check it, before you realize you need furnace repair in the middle of the winter.
Similar Threads: Furnaces winter
HVAC Heating & Cooling Venting 2 furnaces and WH Nov 22, 2016
HVAC Heating & Cooling Oil furnaces Oct 1, 2012
HVAC Heating & Cooling Quick question about forced-air electric furnaces Dec 9, 2010
HVAC Heating & Cooling Comparing trane Furnaces Mar 5, 2009
HVAC Heating & Cooling Do I really need 2 furnaces? Aug 17, 2008
