Furnace Not Working
Discussion in 'HVAC Heating & Cooling' started by JohnO, Apr 9, 2007.
  1. JohnO
    JohnO New Member
    Nov 4, 2006
    New York
    I hear what I believe to be the circulator continuously running and the pilot light is on. However, I cannot get the furnace to run and I am not getting any heat. I know that the contacts are closed in each zone.
    There is a little (what looks like a) bleed valve and it is leaking a little hot water. The hot water in all the faucets is good.
    That is the only thing that I can see is wrong. I will try to get a photo.
    Any help in the interim would be appreciated. Thanks
  2. jadnashua
    John, circulators and zone valve imply a hot water boiler. Is that what you have?
    In a boiler, there are numerous safety monitors. Low pressure, high pressure, over temp, flame sensing, and more if it is a closed system like vacuum caused by the forced induction system. Any one of those safety interlocks could prevent the system from operating.
    If you are fairly handy and own either a test light or a multimeter, and can find the wiring diagram, you can isloate what is preventing the system from firing.
Similar Threads: Furnace Working
HVAC Heating & Cooling Furnace suddenly stopped working Mar 18, 2012
HVAC Heating & Cooling Rheem furnace model r92pa not lighting all the time Jan 24, 2017
HVAC Heating & Cooling Chattering Furnace Contactor Jan 7, 2017
HVAC Heating & Cooling Dripping Sound from Attic Furnace/AC? Jan 1, 2017
HVAC Heating & Cooling What could I possible have done to my furnace that messed it up?! Dec 11, 2016
