Funky Tub Drain Setup
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Fein, Mar 29, 2009.
  1. Fein
    Fein New Member
    Jan 24, 2009
    New Jersey
    I have a tub with an integral overflow in a second story bath. The drain for the tub is directly over a sistered joist. I REALLY don't want to move the tub or cut the joist so I set up the drain as shown.
    I can't get the trap watertight (it is slightly misaligned so it doesn't seat properly)- so I will be taking this out anyway. I would appreciate any advice on a better setup moving forward.
    Thanks.
  2. hj
    drain
    No problem with the overflow setup. It is done that way quite often. Scrap the trap with the locknut. They are bad news in a concealed location, and there is no benefit for using it. Get a glued together trap and you will not have to worry about leaks.
  4. Fein
    Fein New Member
    Jan 24, 2009
    New Jersey
    Thanks HJ- you made my day.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Are you using a waste and overflow where it discharges out the rear horizontally?
  6. Fein
    Fein New Member
    Jan 24, 2009
    New Jersey
    The tub and joist run parallel to each other. The overflow is cast into the tub lining. The drain comes off the tub perpendicular to the tub/joist. Is this a probelm?
  7. Fein
    Fein New Member
    Jan 24, 2009
    New Jersey
    Redwood-
    Not sure I understand the comment about the waste and overflow. Water discharges out of the tub shoe horizontally before goes down a long 90 to the trap then about a foot to pass the vent. I filled the tub and it drained very well...
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Your waste and overflow...
    Is it like the one on the left in the sketch below?
    [​IMG]
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I think the what O/P said is that the over flow is molded in to the tub.
    So no need for the W/O assembly I would like to a picture of the other
    side of the tub.
  10. Fein
    Fein New Member
    Jan 24, 2009
    New Jersey
    Overflow pic attached.
    Code calls for 1.5" pipe- I assume this will pass since it has greater cross sectional area- but not 100% sure. Anyone know of any problems with this type of overflow passing inspections?
    Thanks.
  11. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    No, as long as the piping attached to it up to code.
  12. Redwood
    Dec 15, 2007
    Service Plumber
    I missed the integral part...:eek:
Similar Threads: Funky Drain
Plumbing Forum, Professional & DIY Advice Funky-ish odor in kitchen sink Jul 8, 2014
Plumbing Forum, Professional & DIY Advice Dewinterizing foreclosed condo unit, funky/no water pressure!? Jul 12, 2013
Plumbing Forum, Professional & DIY Advice New Vanity w/ Funky P Trap "bottle trap" May 27, 2013
Plumbing Forum, Professional & DIY Advice Funky S-trap Jun 28, 2011
Plumbing Forum, Professional & DIY Advice Funky Sink Trap Problem Jul 21, 2007
