Fuel Oil Lines Exterior Specs NJ
Discussion in 'Boiler Forum' started by rlbarkleyii, Aug 4, 2009.
  1. rlbarkleyii
    rlbarkleyii New Member
    Aug 4, 2009
    Recently a relative had a oil spill from the use of a brass nipple and cap on a exterior fuel line. Nipple had water in it and split. What are the NJ or National code requirements for exterior fuel lines (pipe) ?
  2. hj
    fuel
    It makes no difference, if there is water in the oil and it freezes, it will break any weak spot in the lines.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    NFPA 54 and the Nat. Fuel Gas code.
    Most exterior oil line piping is done with soft copper but you do still have a valve at the tank that is brass or bronze. There must have been a crap load of water in the tank though. I have never seen and exterior oil line freeze and split and it gets a whole lot colder up here than in NJ.
Similar Threads: Fuel Lines
Boiler Forum Fuel Smart Hydrostat 3200 plus and damper issues Nov 25, 2016
Boiler Forum New Boiler: Size, Brand, Fuel Jan 4, 2016
Boiler Forum Boiler Fuel Nozzle Oct 8, 2012
Boiler Forum Phoenix propane fueled unit for Radiant and DWH or alternative? Mar 24, 2011
Boiler Forum 1/2" tankless coil - what size supply lines? Oct 14, 2012
