Frost proof faucets
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by howarddor, Nov 14, 2007.
  1. howarddor
    howarddor New Member
    Nov 14, 2007
    Retired
    Knoxville,TN
    I have a new frost proof faucet and it continues to run a small stream when shut off. I'm sure of the inner works of a frost free. Any ideas why it won't completely shut off. Howard
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Frost free wall hydrant use washers same as a compression cartridge, over time the washer molds to the seat and wears out.
    You should be able to remove the nut holding the shaft and replace the washer, but it's not easy most of the time.
    Most frost free's are threaded into a fitting in the wall you may want to replace the unit if you can, it would be easier.
  4. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    First question is, what quality of faucet? If you went down to the hardware store and got a junker, then you got a junker. If it's good quality, did you solder it? Or is it a thread-on?
    For most of these type faucets, the problem would be a rock or piece of debris holding the washer off the seat. Or it could simply be a manufacturing defect. If soldered, it could be a drip of solder that got between seat and washer.
  5. Ian Gills
    Jul 24, 2007
    USA
    Or a burnt washer? It sits pretty close to the end if you soldered.
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    If it old I would go for a replace every time. If is rather new pull it apart and replace the washer and see if the seat is ok. The seat is the part the washer sits on.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    The quarter turn hose bibs do not use washers, and most hose bibs are not threaded to the piping system, most are soldered.
  8. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Some inexpensive frost-free hydrants use an O-ring instead of a compression washer, and I've seen split O-rings in them.
  9. howarddor
    Nov 14, 2007
    Retired
    Knoxville,TN
    This is a new 1/4 turn. I removed the stem and did not see anything that was apparent. It did have 2 O rings on it about 1 inch apart. I did not inspect them very close. Howard
  10. Ian Gills
    Jul 24, 2007
    USA
    A quarter turn frost-proof. I have never seen one of them. Wish I had one.
  11. howarddor
    Nov 14, 2007
    Retired
    Knoxville,TN
    1/4 turn frost proof
    This faucet is a B&K 1/4 turn faucet purchased at Home Depot. Lowes also has an American Valve 1/4 turn around $25. I am going to remove the stem again and see if the O rings might be cracked. I have to do something before hard freeze. Thanks for the replies from all. Will let u know if I find the answer to the problem. Also was not soldered. Threaded into female connection.
  12. Peanut9199
    Apr 23, 2007
    Ontario, Canada
  13. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I have seen sillcocks that are female that get threaded onto a brass nipple or male adapter. If it does have male threads then it sounds like a boiler drain acting like a sillcock. I would not waste alot of time dealing with it and just replace it with a new one. What is your time worth to you. What is going to take longer hunting down parts or spin it off and replace with new.
  14. howarddor
    Nov 14, 2007
    Retired
    Knoxville,TN
    Problem solved. Even though this was a new out of the box faucet,it was defective. I brought a new one and just exchanged the stem and the water shut off completely. Thanks for all the advice. HOWARD
Similar Threads: Frost proof
Plumbing Forum, Professional & DIY Advice Frost proof faucet leaking into house Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Frost proof hosebib Oct 12, 2016
Plumbing Forum, Professional & DIY Advice Soldered Stem -Mansfield Frost-Proof Sill Cock Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Nibco 62/762 frost proof sill cock disassembly and repair. Nov 9, 2015
Plumbing Forum, Professional & DIY Advice Ball Valve Frostproof Sillcock - v2 Quarter Ball Feb 20, 2014
