My front loading washer is leaking water. Not from drain hose, not from water outlet hose to pump. Drain pump has been replace and is not leaking. Door gasket appears intact and is dry between door and drum. Instead, there is leaking under drum inside the housing. Can see it at the bottom where curved plastic is bolted to drum and there is a open slot pointing toward the front of the washer. What can I do to fix this?
Model Frigidaire FTF2140FS1
See photo
See photo
