Freezing Vent Pipes on Roof
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by floerchinger, Feb 5, 2007.
  1. floerchinger
    floerchinger New Member
    Feb 5, 2007
    My husband and I live in Iowa where our winter weather has turned extremely cold (currently 7 degrees). Our home has two 3" vent pipes and one 2" vent pipe on the roof coming from our bathrooms/kitchen. Over the last week, each of the pipes have frozen over. When this happens, our basement smells of sewer gas. To eliminate this problem, we have had to climb up on the roof and pour hot water down each pipe to unfreeze them. Any ideas on how to eliminate the vent pipes from freezing (aside from not using any hot water)? Any suggestions will be greatly appreciated. Thanks.
  2. Rancher
    Rancher Guest
    Frozen over... I assume because of snow? I don't know if this is legal or to code, but you could dry fit 2 street ells to the top of the vents, that should keep the snow out.
    Rancher
  4. floerchinger
    Feb 5, 2007
    Thanks for your response. However, they freezing is not due to snow, just frigid temperatures. The steam rising up out of the pipes freezes when it reaches the roof line and causes the pipes to freeze over.
  5. Rancher
    Rancher Guest
    Heat tape down the vents?
    Rancher
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    It's not snow, it's steam coming up the vents, condensing and freezing.
    Next summer change all the vents so that 4" pipe comes through the roof.
    Don't take long showers.
    Wrap a short heat tape around the vent pipes.
  7. floerchinger
    Feb 5, 2007
    Thanks for the advice. I sure hope it works.
Similar Threads: Freezing Vent
Plumbing Forum, Professional & DIY Advice Preventing freezing of an exposed section of sewage ejector discharge line... Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Preventing pipes from freezing......? Dec 17, 2009
Plumbing Forum, Professional & DIY Advice Sump discharge- tie into downspouts AND prevent freezing? In Ohio Mar 8, 2009
Plumbing Forum, Professional & DIY Advice Preventing sump pump discharge lines from freezing? Oct 3, 2008
Plumbing Forum, Professional & DIY Advice Vent Freezing Feb 16, 2008
