Franklin J-Class Pumps
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by clayswim, Apr 19, 2012.
  1. clayswim
    clayswim New Member
    Apr 19, 2012
    Evaline, WA
    Has anyone had any experience with the Franklin J-Class pumps? They have a Franklin motor, which is good. What I'm not sure about is the quality of the pump itself.
    Clayton
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Franklin bought out Jacuzzi. It is an old Jacuzzi design. It is as good as any, but no better than the others either. The Franklin motor is about the best you can do, even though they have also been cheapened up as much as possible. Pumps use to be designed to fail in an average of 7 years. The even more cheapened up versions I see at the big box stores were probably designed to last ½ that long. The best you can do with any pump is limit the amount of cycling on and off, which is the biggest killer of pumps. Since there are now things available like the Cycle Stop Valve, pump companies have had to cheapen their pumps even more to stay within their planned obsolescence timelines.
  4. clayswim
    clayswim New Member
    Apr 19, 2012
    Evaline, WA
    Thanks. I already have a CSV on the system, but it might not have been enough to help my Pentek pump. After 18 months of use the pump is tripping the breaker, and the readings don't seem to indicate that the wires are exposed to ground. When I read between the yellow and black I get 4.4, between the yellow and red I get 0.8, and between the black and red I get 4.4. I know those readings are odd, but I'm also not sure what they mean. This weekend I'm pulling the pump, so I guess I'll find out then if I need another one.
    Clayton
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    make sure you have a good control box. But the jury is still out on those motors.
  6. clayswim
    clayswim New Member
    Apr 19, 2012
    Evaline, WA
    Something else I noticed is that when the pump first went out, there was water running out of the CSV. Is this normal?
    Also, any opinions on whether I should get a 2-wire or 3-wire pump? My well is 118' deep, with water 59' below the surface. I have the pump at 100'. Very clean water.
    Thanks,
    Clayton
  7. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Some of the red and white valves do tend to breath (leak) at the seam but I'm advised that's acceptable. If you have a problem with the leak you may want to replace it with a CSV1W or the new Stainless Steel Valve CSV1A http://www.cyclestopvalves.com/products.html but they do cost more.
Similar Threads: Franklin J-Class
Pumps and Tanks Well Forum & Blog. Water is life. Franklin Well Control Box Overload Trips Oct 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump sizing and info on Franklin / Schaefer pump 3200 Series Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Franklins new thrust bearing rating back in 1988 & 1989 Jul 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. CSV or no CSV? Berkeley/Grundfos/Franklin? Jul 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Which Franklin motor for use with Grundfos 10S15-21? Jun 19, 2016
