Franklin Electric Sub Drive 75 Constant Pressure system
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by molinsky, Nov 24, 2011.
  1. molinsky
    molinsky New Member
    Nov 24, 2011
    Madison, CT
    I have had a Franklin Electric Subdrive 75 Well Pump System for approximately 6 months. It has been working perfectly until now. For the past 3 days the water has stopped after a 5 minute shower. I checked the gauge on the tank and it was reading 15 (normally around 60). There were no red fault lights. The green light was solid. About 15 minutes later I checked it and the green light was flashing and the pressure was back to normal. This has happened the past 3 days.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If it is only 6 months old, you might give the installer a call for assistance.
    I have heard nothing good about these variable speed drives, except from the people who are making money selling them.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    it sounds like you're running out of water. But those things are suppposed to shut the pump off
  5. molinsky
    molinsky New Member
    Nov 24, 2011
    Madison, CT
    I don't think I am running out of water because according to the manual, I should get a red blinking light indicating a fault if that happens. When it occured yesterday I started to take the rubber cap off the sensor and the pump started to run and came up to normal pressure. It has been fine so far today. I am suspicious of the sensor and waiting for it to happen again so I can bypass the sensor and see if it recovers again.
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I don't know what sensor you intend to bypass but I hope you have a functioning pressure relief on the system, because when those controllers go awry, they can easily exceed safe pressures. Maybe you should leave it to an expert given that is should still have warranty.
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    You can actually replace those "sensors" with a standard 40/60 pressure switch. It will cycle much less than when using the "sensor" as they are actually just a pressure switch with only 1 PSI between on and off. Right now that sensor is cycling the pump 45 times per minute. If you use water 24 hours per day, that is nearly 2 million cycles per month. You can also use a CSV with those type systems, and it will take out all the cycling.
  8. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
Similar Threads: Franklin Electric
Pumps and Tanks Well Forum & Blog. Water is life. viberation in franklin electric pumptec Jun 24, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Franklin Electric control box making chattering noie Mar 7, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Franklin Well Control Box Overload Trips Oct 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump sizing and info on Franklin / Schaefer pump 3200 Series Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Franklins new thrust bearing rating back in 1988 & 1989 Jul 21, 2016
