Frameless Shower Enclosure
Discussion in 'Shower & Bathtub Forum & Blog' started by Kathristin, Oct 14, 2008.
  1. Kathristin
    Kathristin New Member
    Aug 15, 2008
    I want to install either a 40x40 neoangle or neoround corner shower in the master bath. The installer that the plumbing supply place recommended is hesitant about installing a frameless enclosure in such a tight space. He says that it will leak.
    These are the enclosures I am looking at (by Maax)
    http://www.maax.com/en/Products/ProductInfo.aspx?Brand=21&CodeCategory=B&ProductType=20&Product=1001
    http://www.maax.com/en/Products/ProductInfo.aspx?CodeCategory=B&Brand=21&ProductType=20&Product=1232
    And this is the one he recommends is
    http://www.maax.com/en/Products/ProductInfo.aspx?CodeCategory=B&Brand=21&ProductType=20&Product=1233
    Is what he says true? Or is he just not a good installer and I should look somewhere else?
  2. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    I think he's worried about the product itself, not the size, since that's the size that they are designed to be. What seals the water spray from the door edges?
  4. hj
    enclosure
    The size of an enclosure should have nothing to do with whether it leaks or not. If it did, the companies would not make them in the first place. The installer determines how good it is.
  5. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    I think the installer meant that he was hesitant to install a frameless shower door in an "tight space" like in a neo-angle installation. I have never seen a frameless neo-angle shower door, but I can imagine that you would get some leaking at the door joints as there is nothing there to seal them against the water being sprayed on the shower walls.
    What you want for a neo-angle installation is a door with a strong magnetic seal to give you the best possible guard against moisture leakage. Actually if you look at your second frameless shower enclosure, you will notice that it has a magnetic strip down the center, which would give you better leakage protection since the spray is usually directed there, but you will probably still have a little bit of leakage at the side of each door where the hinges are if water is directed there.
  6. Howard Emerson
    Howard Emerson I teach guitar:You call that a job?
    Apr 28, 2008
    Huntington Station, NY
    If you'll open up the PDF file given at the link, you'll clearly see that two different clear rubber gaskets are provided to seal where the door butts and where it hinges.
    How well they work, of course, depends greatly on the installer, but also on what he's dealing with prior to his arrival...........
    One of the most importand things with a system like this is that the walls be 'dead-nuts-plumb' and flat, and that the base be set perfectly level.
    The more gaps you have to fill, the bigger the chances of problems down the line.
    Also of supreme importance given the weight of these units is the need for framing to be behind where the header and the wall panels attach.
    HE
Similar Threads: Frameless Shower
Shower & Bathtub Forum & Blog Remodeling my small bathroom with Frameless shower doors: Any Idea?? Mar 10, 2014
Shower & Bathtub Forum & Blog Confused about requirements for frameless shower door & panel Nov 24, 2011
Shower & Bathtub Forum & Blog Need to Fill and Redrill Frameless Shower Door Mounting Holes Nov 4, 2011
Shower & Bathtub Forum & Blog Frameless shower door install Dec 1, 2009
Shower & Bathtub Forum & Blog Frameless Shower Walls - Header Question Dec 10, 2008
