Chris Fox
I have a patio fountain that came with a large rubber stopper(2.5 dia x 1.25" thick) and a short roll of green colored putty tape. The stopper has a slit and a hole in the cetner for the pump cord.
I am having a hard time sealing this stopper up in the basin of the fountain.
I have rolled the putty around the stopper and the slit and the cord but still leaks.
I have tried to use silicon which has worked the best but still leaks. After several attmepts with the putty and silicon no luck. I want to be abel to remove it when I need to drain it so it cant be a permanent fix.
Seems like an easy thing to do but...??
- should I use a nother type of putty. Plumbers putty?
- butyl rubber for sealing?
- technique for using the putty
thanks for your help...
Chris
Chris
