Found something odd. . . .you ever see this
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wed68, Sep 14, 2009.
  1. wed68
    wed68 DIY Junior Member
    Sep 14, 2009
    louisiana
    I am in SW Louisiana and have been working in, on, or around houses all my life. I have plumbed, roofed, hung vinyl, framed, and wired em, but I can not figure out why you would put a bath tub spigot 6 inches off a tiled shower floor!
    This is in a 50 year old house in a rural community, I was looking at it to resell, but I can not figure out what the spigot were for the only thing you can get under them is your feet. You would have to either pull the shower knob up with you feet or bend over to pull it.
    Anybody ever see this across the country?????
  2. Cass
    Cass Plumber
    Nov 12, 2005
    can you post a pic
  4. wed68
    Sep 14, 2009
    louisiana
    I will Try
    I will try
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Handi capped accessable
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    For washing and rinsing the shower floor without getting your hair wet?
  7. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    I have never come across one, but the spigot is meant to be used as a "toe tester" so you can test the temperature of the water with your feet as well as flush out any cold water in the line before you turn on the shower, so you don't get scalded or blasted with icy cold water.
  8. hj
    spout
    I usually put them 12" to 18" above the floor so you do not have to bend over to operate the diverter. They are used so you do not get hit in the face with a jolt of cold water when you turn the valve on. The plumber who put it at 6" above the floor probably figured that it should be 6" above the tub rim so it must also have to be 6" above the floor, not having enough initiative to think why that would be ridiculous.
  9. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Yup. I think that is it.
  10. leejosepho
    Nov 23, 2006
    Well, at least I was close!
Similar Threads: Found something
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Wet spot of home foundation, possibly plumbing leak in pipe going through foundation? Jun 25, 2016
Plumbing Forum, Professional & DIY Advice What do I need to replace corroded cast iron drainage pipes underneath slab foundation? Jan 18, 2016
