Found a green knob in closet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by silversvt26, Jan 24, 2013.
  1. silversvt26
    silversvt26 New Member
    Jan 24, 2013
    Oklahoma
    In our downstairs closet at the bottom of the wall by the door there is a green knob sticking out of the wall. It look slike a water valve you would turn off or on outside.
    We do have a 1/2 bath right behind that wall but if we turn it many times right or left it doesn't seem to make any difference. Anyone have any idea what it might be?
    The reason is I am needing to replace the water inlet fittings to our toilet in one of the bathrooms upstairs and I need to turn the water off. There is no valve under the sink upstairs.
    Any help would be appreciated.
  2. Terry
    Aug 17, 2004
    It may be a water shutoff. If so, it would close clockwise and open counter clockwise.
    If you have an expansion tank, it would take a while for the water to quit draining down. Those can hold about 2 gallons.
  4. silversvt26
    Jan 24, 2013
    Oklahoma
    Thank you for the info. When I get home tonight I will give it a try.
  5. silversvt26
    Jan 24, 2013
    Oklahoma
    That was it and it worked. Thank you!
Similar Threads: Found green
Plumbing Forum, Professional & DIY Advice Cooktop exhausts through thinwall tube though foundation. rainwater problem Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Wet spot of home foundation, possibly plumbing leak in pipe going through foundation? Jun 25, 2016
