Fore / Aft position of Moen Posi-temp valve
Discussion in 'Shower & Bathtub Forum & Blog' started by FJK, Jan 20, 2008.
  1. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    The Posi-temp valve comes with ~7/8" thick, 4-1/2" diameter plastic ring that screws onto the valve. Should the back side of the ring be flush with the front side of the bare stud? This obviously sets the fore/aft position of the valve. I'll be using 1/2" cement board & tile (?? thickness). Will the valve be positioned correctly? If not, how do I set the correct dimension?
    Thanks, FJK
    [​IMG]
  2. jadnashua
    Usually, there are marks on that plaster shield. Normally, it should be flush with the FINISHED wall, or at least within the limits marked on the shield, which could be with it further out. The instructions should say.
  4. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    There are no marks on the plastic shield. If I have to estimate, is it better to have it stand proud or be slightly recessed?
  5. jadnashua
    Call Moen. If the printed instructions do not tell you where it should be and the limits, it is severely lacking. You could get a good idea if you assembled the trim to check how long the screws are and how easily you can attach the handles. Some models are very fussy and must be quite exact, some are quite flexible. Now, this does not mean that you will like the handle sticking out if you have it too far out. But, as long as the trim will fit, technically (not necessarily asthetically) it is okay.
  6. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    http://terrylove.com/forums/showthread.php?t=17741
    I posted a pic of the instructions, which can be found on Moen's website based on your model #.
    The part of the pic I posted is the setup for walls thicker than 3/16" IIRC.
    For thinner walls, I *THINK* the ring is reversed and goes behind the finished wall instead of flush. But again, check the Moen site as I may be recalling incorrectly.
  7. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    The surface of the finished wall should be within the range of the thickness of the flange. If your wall was 2" thick, it would do no good to meet it to the stud. The plastic flange is particularly handy for mounting to the back side of a fiberglas shower, and it's good for establishing the range of space allowable for installation.
    To get an idea, place the trim on the valve and allow for the thickness of your finished wall and you can see how deep in the wall to place the valve.
Similar Threads: Fore position
Shower & Bathtub Forum & Blog Shower base install - cbu before or after? Nov 18, 2016
Shower & Bathtub Forum & Blog Elbow before p trap. Apr 21, 2015
Shower & Bathtub Forum & Blog Leaking valve in shower - Have you seen this type of valve before? Nov 8, 2014
Shower & Bathtub Forum & Blog I Need Advice Before I Tile Shower Jun 25, 2014
Shower & Bathtub Forum & Blog Rough-in Side Wall Before or After Installing Alcove Tub Mar 26, 2014
