DustyThermos
Hello,
I have a Grundfos Centrifugal Pump for drinking water systems. The part number for this item is CRN14 A-E GJG-HUUK. It is powered by a Baldor Reliance motor, for which specifications are listed below. The pump information is not printed into the specification plate. Pump is fully functional.
0.5 HP
230/460 volts (also useable at 208 v/2.5 amps)
2/1 amps
1725 rpm
60 Hz
3 Phase
The following info is also provided on the pump:
Classified UL
Water Quality
ANSI/NSF61
Drinking Water System Components
65 GM
23 Degrees Celsius/ 73 Degrees Fahrenheit
Centrifugal Pump
0.5 HP
2/1 amps
1725 rpm
60 Hz
3 Phase
Classified UL
Water Quality
ANSI/NSF61
65 GM
Centrifugal Pump
