1. sola_fide
    sola_fide New Member
    Jul 12, 2009
    Hi,
    I have an irrigation system that gets water from a lake. The intake 1.5 inch pvc pipe is about 60 feet long with a foot valve on it. The lake level fluctuates in the winter up to seven feet. I have a hose
    bib near the middle of the intake line to let the water out of it, but it didn't get low enough to
    access it this winter. The pipe froze and broke. Leaving the foot valve off would probably
    keep the problem from happening next winter since it could drain, but it keeps sand out of the line which a screen might not. I was wondering if there was a foot valve that would drain itself (not act as a check valve) or some better low maintenance way to keep it from freezing other than removing the pipe every year? Thanks
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    connect the lake drop to the line with a 1 1/2" mission band so you can disconnect it and pull it out in the fall.
  4. sola_fide
    Jul 12, 2009
    OK Thanks :)
Similar Threads: Foot valve
Pumps and Tanks Well Forum & Blog. Water is life. Best Of Best Foot valve Manufacturer? Feb 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Foot valve, stock re-plumb, or modified re-plumb Jan 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Jet Pump losing prime with new foot valve after sitting 4 -5 hrs Aug 12, 2015
Pumps and Tanks Well Forum & Blog. Water is life. No water after repairing footvalve Jun 20, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Foot valve or swinging valve? Jul 6, 2014
