1. kingfisher
    kingfisher New Member
    Jul 21, 2007
    Hello,
    What is the purpose of a foot valve? I have an existing well with 1 1/4 pipe at 31 feet total well depth. I have static water in pipe at 19'. I have a gauze type point that is about 3' long.
    What would a foot valve in the well do for me.
    kingfisher
  2. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    I believe it is a check valve that keeps water from draining out of the pump/pipe assembly. I also believe that this is used on a jet pump that would lose prime if it drained.
    Someone who is more experienced will answer.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I think you described an 1-1/4" well. If so, you don't want a foot valve in your well, it would have to be a 3/4" to fit into the pipe and would be a bad restriction on your suction inlet to the pump. Just use a check valve (1-1/4") as close to the well as practical.
    bob...
  5. kingfisher
    Jul 21, 2007
    Thanks Guys!
Similar Threads: Foot Valve
Pumps and Tanks Well Forum & Blog. Water is life. Best Of Best Foot valve Manufacturer? Feb 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Foot valve, stock re-plumb, or modified re-plumb Jan 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Jet Pump losing prime with new foot valve after sitting 4 -5 hrs Aug 12, 2015
Pumps and Tanks Well Forum & Blog. Water is life. No water after repairing footvalve Jun 20, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Foot valve or swinging valve? Jul 6, 2014
