Soca
I bought a small section of the sprinkler wire. I cleaned up the ends of the old wires and attached the new section. As a temporary fix, just to test the system, I attached the wires using twist-on connectors. The backyard sprinklers now work. But, here's the problems that I'm stuck with. The previous owner ( and sprinkler installer ) literally wedged the wire between the water supply line and drain pipe leaving me with almost no working room. In the interest of space, can I use electrical tape to connect the wiring ? Then, maybe coat each tape job with a layer of ( Dap ) 100% silicone rubber sealant ? Thanks much for the help.
