Flushmate problem//need help??
Discussion in 'Toilet Forum discussions' started by vw92001, Aug 22, 2005.
  1. vw92001
    vw92001 New Member
    Aug 22, 2005
    Greetings. i have a flushmate model #14-101526f in an amercian standard toilet..When pushing the handle down it goes down very slowly. Have to use a bucket of water to get it down. I tried plunging..thinking possible blockage. It didn't help. Plus water shoots out of the toilet/tank lid..I believe the water is coming from the discharge extension w/drain....
    Any ideas what this could be???? Solutions??
    thxs
  2. jimbo
    jimbo Plumber
    You should not be getting water inside the tank on flush. At the very least, you would need to replace the flush cartridge. This would probably fix the problem. And if you are dumping pressure inside the tank, this would account for the poor flush.
  4. vw92001
    vw92001 New Member
    Aug 22, 2005
    Thxs....
    Will Check It Out...
  5. vw92001
    vw92001 New Member
    Aug 22, 2005
    Would the flush cartridge really be the problem? I looked at the toilet while flushing it and the water looks like it coming out of the black tank somewhere on the bottom. Flushmate told me that the discharge extension could be worn/bad. Does this sound correct?
    I think the only reason the flush is weaker is because some of the water is leaking out of the discharge extension. Have you heard of this before? Do you think I have to seperate the two pieces of the toilet to change the discharge extension?
    Thanks !
  6. jimbo
    jimbo Plumber
    Could be, but the cartridge seals off the discharge extension during flush, so since it is easier to replace the cartridge, I suggest trying that first.
  7. vw92001
    vw92001 New Member
    Aug 22, 2005
    will do...
    thxs
  8. Dude
    Dude New Member
    Aug 28, 2005
    Unless this Flushmate is several years old or experienced severe chemical degradation , it's unlikely that the cartridge is an issue. If the china holding tank is properly installed the leak is most likely originating from the flapper in the discharge extension or the interface between the discharge extension and the Flushmate tank. Either is possible; neither are common.
    The Flushmate Technician should be able to identify the cause and provide a resolution.
    It may not be possible to replace the discharge extension only but the Flushmate Tech can clarify this. Under the circumstances, they will probably want to replace the entire Flushmate and retrieve yours for conffirmation of the diagnosis, etc. Either way, it is necessary to unbolt the china holding atnk and remove the Flushmate. It's pretty simple; there are only two plastic locknuts holding it in place.
    Hope this answers your questions, better late than never I suppose.
    D.
Similar Threads: Flushmate problem//need
Toilet Forum discussions Flushmate external regulator leaking Nov 18, 2016
Toilet Forum discussions Sloan Flushmate m-101526-f3 won't flush Jul 10, 2015
Toilet Forum discussions HELP!! I can't flush my Sloan Flushmate (Gerber) toilet!!! Jun 20, 2014
Toilet Forum discussions Looking for people in Western WA. who have the recalled Flushmate III toilet system ? Mar 11, 2013
Toilet Forum discussions My flushmate was recalled and Bucket flushing doesn't really work! Oct 5, 2012
