flushmaster toilet fills/runs longer than normal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gcook, Jul 2, 2007.
  1. gcook
    gcook New Member
    Jul 2, 2007
    I have a 1 button flushmaster toilet. There is a black plastic container inside the back of the toilet, so there is no water that fills, except inside the black container.
    When I flush the toilet it is not filling up immediately. It is running. It is is similir to a standard toilet when you flush it and the stopper comes up and doesn't close correctly so the tank never fills. I am not sure how to troubleshoot this one. I took the top of the back after I flushed it and toggled the lever that goes into the black tank, up and down a few times and it seems to fill. Do you know how I can fix this? The toilet eventually fills and stops running, but you have to tinker with the flush button until it does "something", and starts to fills.
  2. jimbo
    jimbo Plumber
    It sounds like you have a Sloan Flushmate in your tank, it that correct? The cartridge right in the middle can be replaced and will solve your problem. Confirm the Sloan model number on the black tank, and any plumbing supplier should have the part. It comes with installation instructions, and is not difficult/
Similar Threads: flushmaster toilet
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Toilet flange too high? Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Option for adding to my soil stack for second toilet. Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Need 10" skirted toilet in ADA Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Relocated Toilet Drain Directly Above 2x10 Floor Joist Feb 7, 2017
