Flushing sediment from well after deepening
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by biel, Feb 13, 2012.
  1. biel
    biel New Member
    Feb 13, 2012
    NH
    We have recently had our well deepened and are now dealing with sediment that I can't seem to flush out.
    Here is some more details. The well is about 30 years old, originally it was 300'. When we moved in about a year and a half ago, the well had a low yield, about 1 gpm. The water was of good quality, clear, never had any issues with quality other than radon for which we have an system installed. 2 weeks ago, we hired a local driller to deepen the well. We deepened the well to 560' and got a yield of 7gpm, which is great. Once the driller left, we were instructed to flush it since they chlorinated it. They said the water would be cloudy for a few days but just to keep on flushing it by running a hose outside.
    I have been running the hose for 2 weeks now and really see no difference in the quality of water. The water is still cloudy and gray in color. We have an inline filter and put in a 5 micron filter in but that does not seem to make much of a difference, plus it fills up within a couple hours. Once removed, the filter is covered in very fine, gray muddy substance.
    So, I have been running the hose every day for 2 weeks straight. First I ran it for about an hour at a time, then I increased the time to 2 hours, and most recently to 3 hours at a time. I still see no difference in the quality of water. I called the driller this morning and he told me to run two hoses, one into the woods and one back into the well. I started doing that this morning. So far, I see no difference. I have been flushing it for 3 hours already.
    Does anyone have any ideas of how to get rid of this sediment? By the way, we installed a new 1hp pump which is set at 500', so 60' off the bottom.
    Thanks for any suggestions you can offer! I just want my clean water back!!!
  2. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    What do you mean by 3 hours at at time? If it's 3 hours per day I don't think that would be enough and I would run it non-stop for 3 days.
  4. biel
    biel New Member
    Feb 13, 2012
    NH
    The driller said to pump for 3 hours then let it recover for an hour and pump again.
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    The driller advised you right! It should clear up eventually. Sorry about the cloudyness and silt but many times that happens when drilling or deepening a well. You should see an improvement soon, if not call the driller back and stay in touch with him as to the improvement or non-improvement.
  6. biel
    biel New Member
    Feb 13, 2012
    NH
    Thanks Porky. Do you know how long this process can take?
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The less water a well produces, the longer it takes to pump it clean. I have a 1 GPM well that took about two months to clean up. Then I shocked it and it took another two weeks just to get the chlorine smell out. Run two hoses, keeping the pressure low, and just keep pumping. If it doesn’t clean up in a month, call the driller back.
  8. biel
    biel New Member
    Feb 13, 2012
    NH
    We flushed the chlorine out in about a day, so it didn't take too long. This is day two of running two hoses, one into the woods and one back into the well. I am hoping a few days of this will do the trick.
    Would you recommend running the hoses all day or continue to do it in 3-hour increments?
Similar Threads: Flushing sediment
Pumps and Tanks Well Forum & Blog. Water is life. Flushing sediment question #2 Feb 17, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Flushing out new well May 1, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Use Sump Water For Toilet Flushing Apr 19, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Well cap replacement, now metal sediment in system Sep 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sand / sediment in water - need help resolving Apr 8, 2016
