HELP!
I purchased one of these new high efficiency toilets and I am having bad flushing issues.. This toilets does not flush at all.
ok to break it down...
Toilet installed used wax ring with flang.. flushes for 4 hours then stops...
Called American Standard support they told me to change the wax ring without flang...
So I pull the toilet.. swap out the wax ring.. put the toilet back on and still had flushing issues. Opened the clean out to make sure it was not a clogged pipe.. went inside the house used a plunger many times and got it to flush another 4 or 5 times.
The pipe below the toilet is wide open, clean out is off for air into the sewer lines. Cannnot get water to go from toilet to drain!
Any advice before I return this toilet and get a regular toilet?
Thanks,
Craig
Thanks,
Craig
