Flushed radiant water heater, now confused
Discussion in 'HVAC Heating & Cooling' started by brador, Jul 3, 2008.
  1. brador
    brador New Member
    Jun 12, 2007
    New York
    Whoops. I have just flushed out the water heater for the radiant system. However, the water flow wasn't what I expected, so now I'm not certain how to make sure the water heater has no air pockets. Also, I'm not sure whether I need to purge air from the system itself. And for that matter, how to do either. The components are:
    - Fed by domestic with backflow prevention valve
    - Single zone, 6 PEX manifold
    - Just one drain value (not counting water heater drain) at the manifolds
    - Pressure tank and pump
    - Water heater
    - A Motorola valve I can set to "open"
    Any help appreciated. I've been reading some materials here and other sites but can't quite figure it out. Many thanks!
    UPDATE--The system has an auto purge, so when I filled the water heater and turned on the circulation pump, there was much hissing and gurgling, gradually getting very quiet. I can't see or hear any air in the system. Am I safe? Is there still a chance of air pockets in the water heater (nonononono) or radiant PEX?
  2. jadnashua
    If the water is circulating (and that's a big if in the pex lines), then any residual air trapped there will be pulled out by the air scoop extraction device. Depending on the elevation differences, it can sometimes be a pain to get all of the air out of loops.
Similar Threads: Flushed radiant
HVAC Heating & Cooling Radiant heat and domestic water on same system? Feb 13, 2017
HVAC Heating & Cooling Radiant in concrete - Higher temp/more cycles versus Lower temp/constant circulation Jan 11, 2017
HVAC Heating & Cooling Radiant in slab heat questions Jan 8, 2017
HVAC Heating & Cooling Radiant Floor Heat in Bathroom and other ramblings... Jan 7, 2017
HVAC Heating & Cooling In floor Radiant heat not working (under concrete slab) Jan 3, 2017
