Flush-Mate toilet at new Motel 6
Discussion in 'Toilet Forum discussions' started by mjnelson99, Jun 22, 2007.
  1. mjnelson99
    mjnelson99 New Member
    May 5, 2007
    I recently stayed at a brand new Motel 6 in San Jose, CA.
    Their ADA toilets are Flush-Mate with the black "box" in the tank. I did not see a brand on the bowl itself. Inside the tank it said "Made with pride in the USA."
    When flushing the water just bubbled a lot with the toilet paper staying in the bowl. At first I thought it was just plugged and the manager brought a plunger that made no difference. We discovered that if the handle was held down until the water finished flowing, the flush was better.
    Even holding the handle down when I put in a bit more toilet paper cleaning up a water puddle on the floor, it took 3-4 flushes to get it cleared.
    After this experience I would be very reluctant to put in a Flush-Mate toilet.
    It is possible they were required to put this type of toilet in.
    The plumbers who did the work did not do the best job I have seen. The aerator on the lavy looked like it did not have a washer and water leaked and sprayed over and around the faucet. :(
    Terry sounds like he is much more conscientious than the guys who worked on this motel. :)
  2. jimbo
    jimbo Plumber
    There is usually a manufacturer's name and/or model number printed or molded into the porcelain, on the inside of the tank. It may also be on the bowl.
    I have had a Mansfield toilet with Flushmate since 1992 and have been very happy with it.
    Sometimes there is a complaint about paper "floaties" because the power flush breaks it up. I do not have that issue, and to me your Motel 6 sounds like the drain is clogged, or the Flushmate is defective.
    Today, there are alternatives to the pressure assist, in the form of the large flush valve.....toto Gmax, AmStd Champion and Cadet 3, Eljer Titan, Kohler Cimarron. All of these in general flush probably as well as a pressure assist. I still like the pressure assist myself, but they are pricey, and pricey to repair ( very reliable and long lasting)
  4. Scott
    Scott Flushmate
    Nov 2, 2004
    Tech Support
    Detroit, MI
    Pressure-assist tanks are basically a storage and delivery system. Any inconsistencies or defects in the actual toilet bowl and any partial obstructions in the trapway, drainline, or vent-stack will most assuredly affect performance and extraction.
    Holding down the handle for a "better" flush indicates that there's improper clearance between the actuator cap on top of the flush-valve cartridge which is easily resolved by loosening a set-screw, adjusting the actuator cap to the 1/8" clearance specified in the Flushmate's installation/owner's manual, and tightening the set-screw to maintain the appropriate clearance.
    It' likely that the performance you experienced was the combined result of a pre-existing plumbing/fixture problem and a poorly adjusted handle/linkage assembly.
    Unfortunately, no toilet can overcome the need for a clear, unobstructed DWV system and no flushing technology can compensate for a defective bowl that may have constricted raceways or excess glaze obstructing rim or jet outlets.
    Maybe the next Flushmate you encounter will be a more realistic example of the performance most get from their pressure-assist fixtures.
Similar Threads: Flush-Mate toilet
Toilet Forum discussions Question about flush-mate Apr 19, 2005
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Toilet leaks than stops Feb 16, 2017
