Pugzilla
First post from this Newbie. I have just had installed 3 Ultramax 1.28 GPF toilets and 1 (Eco?) Drake 2-piece 1.28gpf in my house. My daughter has the slightly older 1.6 models in her home. Although I haven't stressed them yet, the new flush system appears to be quite good.
I did note that the flushing levers appear loose and the arc it takes appears to drift away from the tank as the lever is depressed - this is not the case with my daughter's. Is this the way it was set up (all the flush levers on the toilets installed appear to function the same way) or is there a problem with the installation?
Also, on the Drake, the water level in the tank seems to vary with the length of time the lever is depressed. Correct?
Thanks for any help you can give me. Model numbers on request.
Best regards,
Pugzilla
Best regards,
Pugzilla
