Fluid Master 400a Loud
Discussion in 'Toilet Forum discussions' started by rldev, Sep 25, 2005.
  1. rldev
    rldev New Member
    Aug 24, 2005
    New Jersey
    Hello Folks,
    I just replaced the fill mechanism of an old Kohler one piece toilet with a Fluid Master 400a. The toilet is not very loud when filling up. I have tried adjusting the water supply, but it is loud or acceptable but takes a very long time to fill the tank. Fluid Master is a good pruduct, right? Anything I can try?
  2. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    i just replaced my 2 f. masters with Korky quiet fills
    they are very quiet, and i notice the flush handle takes very little pressure to flush. i,m staying with Korkys from now on
  4. rldev
    rldev New Member
    Aug 24, 2005
    New Jersey
    Where would I find these?
  5. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I go through cases of Fluidmaster400A's a year and no callbacks, ever. Sounds like you possibly have high water pressure. Check to see what it is. Fluidmaster is the best selling fill valve out there. Kohler toilets basically are equipped with a 400A with their house brand tag on them. Those Korky's are good as well but I would determine water pressure before making any choice.
  6. Terry
    Aug 17, 2004
    I use both the Fluidmaster 400A and the Korky Quietfill for replacement valves.
    Fluidmaster 400A
    Easy to install
    Easy to adjust
    Easy to find, found in all hardware stores.
    Korky Quietfill
    Easy to install
    Almost as easy to adjust
    (There is a plastic key that locks the adjustment, once you figure out this simple thing it's easy)
    Quieter
    Less water hammer.
    Found in most, not all hardware stores
  7. rldev
    rldev New Member
    Aug 24, 2005
    New Jersey
    What tool can I purchase to determine water pressure. I have a few areas I would actually like to measure.
  8. Dunbar Plumbing
    Apr 18, 2005
  9. hj
    Either it is "not very loud when filling up" or it is "loud or acceptable", which? If it is slow to fill and loud, you have something caught in the system creating a slow fill and turbulence causing the loud whistle.
  10. cn90
    cn90 New Member
    Jan 13, 2009
    Nebraska
    Use Fluidmaster W43C!!!
    Sorry to re-activate the old thread but I have been using the 400A valve: it is noisy!!!
    So I called Fluidmaster HQ in California, they say the Kohler Fill Valve "Ingenium" is the same as Fluidmaster W43C. "W" stands for "Whisper". The W43C has a Rubber Flow Restrictor at the bottom of the Inlet Shank. Otherwise both 400A and W43C are essentially the same.
    For now, only Home Depot sells this W43C Valve for $9.50 (a flap is also included in the package).
    I just swapped the 400A for the W43C, wow.......BIG difference! Nice and quiet as brand new!
    You might want to turn the Toilet Shut-Off Valve down a bit until you are happy with the noise.
    Hope this helps!
  11. seattleplumber
    seattleplumber Service plumber.
    Jan 13, 2009
    Service plumber.
    Seattle, WA
    Use the Pro 45-B
    Fluidmaster makes a fill valve with a brass shank called the 'Pro 45-B' that is almost identical to the 400A. It is much more quiet.
Similar Threads: Fluid Master
Toilet Forum discussions Fluidmaster7500 vs 7530 Jan 27, 2016
Toilet Forum discussions FLUIDMASTER 7530 WAXLESS SEAL AND NEW TOTO TOILETS Jan 22, 2016
Toilet Forum discussions Mansfield No.35 compatibility with Fluidmaster 400 AKR complete repair Apr 25, 2015
Toilet Forum discussions Fluidmaster DuoFlush; converts a toilet into a dual flush toilet. Sep 22, 2014
Toilet Forum discussions Fluidmaster 400A shuts off but then slowely fills to the top of the fill tube Aug 11, 2014
