Flowguard Gold CPVC vs PEX
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MountainMike, Apr 9, 2013.
  1. MountainMike
    MountainMike New Member
    Apr 9, 2013
    Floyd, Va
    Does anyone have any experience with Flowguard Gold CPVC and it's performance/ease of installation vs PEX?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I score the match a tie at zero, zero
  4. jadnashua
    As you can tell, Tom doesn't like plastic supply pipes! If I were going to chose between them, I'd go with pex. Copper is still the gold standard. To do it in pex, you'd want to 'upsize' the supply lines or at least carefully match the load with the supply since the ID is thinner than copper. A repipe is a lot easier with pex. On new, I'd have to think about it...lots of things to consider.
  5. Terry
    Aug 17, 2004
    I like PEX better then CPVC
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You would also have to up size CPVC. Just like PEX, the inside diameter is about a size smaller than copper.
  7. hj
    In this area, FloGard has been used for residential fire sprinkler systems for decades, but I have not seen any installed with PEX, but that does not mean it is not used for that purpose. CPVC has the disadvantage on needing many more fittings to install it, but it is also more rigid giving a better appearance.
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    Uponor/Wirsbo makes several "systems" for sprinklers and PEX
Similar Threads: Flowguard Gold
Plumbing Forum, Professional & DIY Advice FlowGuard gold pipe breaks Oct 27, 2013
Plumbing Forum, Professional & DIY Advice Replace Flowguard Gold on a remodel? Nov 10, 2011
Plumbing Forum, Professional & DIY Advice flowguard gold Aug 25, 2010
Plumbing Forum, Professional & DIY Advice Pex vs FlowGuard Gold Oct 6, 2009
Plumbing Forum, Professional & DIY Advice Flowguard gold vs regular CPVC May 14, 2008
